Yep, 5858 is pretty small be careful in closed loop.
It’s all together and runs great but the lean condition is not acceptable. I’m concerned there’s people with a turbo probably running lean in part throttle. That can do some serious damage. The closed loop management is strong and appears keep it at stoic up to 2psi which isnt going to work. I have an adjustable rising rate regulator I’m going to install and I’m hoping to have it come in at 5” of vacuum and up. If it won’t keep it in the 12-13s above the 5”s, I’m going to get the Split Second enricher to manipulate the o2s signal to the ecu to get the afrs where I want. Both corrections should work. Both aren’t too expensive. A piggy back or full ecu swap is just too much of a hassle and I don’t want to go there. If I can manage the afrs it’s going to be awesome.
Good to see another turbo attempt! I would watch that size turbo and going lean in closed loop.
The pending correction is part throttle not full throttle. LOL
Full throttle in due time.
The size of the turbo will not effect the loop status in the part throttle range,
Id rather have this 5858 fast spooling BB turbo than any of the oversized slow journals I've seen people are running.
This is the perfect turbo for 10psi. Its rated at 600HP Ill never get anywhere near there.
The FPR is rising rate with both the target for its activation and rise being adjustable.
Blip Speed VRG FMU - Blip Speed Motorsports
Product Overview When you need more fuel flow to maintain the correct air/fuel ratio the Blip Speed VRG fuel pressure regulator is an ideal alternative to expensive ECU or fuel injector changes. This type of regulator is also referred to as a FMU (Fuel Management Unit) or Rising Rate Regulator...www.maxgms.com
Enricher
Ill never get to 19% but thanks for the info.
You predicted it because most people are using an over sized slow spooling turbo on a stock ECU and I won't.
Its proven you can use one of those slow spoolers and maintain near proper fueling at part throttle in closed loop.
It will take fuel management to use a fast spooling turbo. I am more than ok with that.
Id much rather spool quick stay closed loop and manipulate the FP/ECU to manage it.
I don't know if one or both of the fixes will do the job but I do know it will work.
Looking forward to the testing.
Dropbox - File Deleted - Simplify your life
www.dropbox.com
Little ride video
Most people are doing it because it works. And the stall on the torque converter is 1800rpms. How many turbo'd 80's have you driven?
I have tried to give constructive criticism because I was where you are 4+ years ago, but I will let you work it through.
The info is all appreciated and received. I trust the wideband and believe Ill get a correctly fueled 80 using the stock ECU. The ECU is doing a good job as it was programmed to do and that doesn't mean its too old to manage the system with the right fuel manipulation.
In the end anyone using a turbo on one of these needs to know how well the split sec enricher and 2025 FMU help to manage the fuel. I don't see anyone trying it on an 80 but I see plenty of examples on similar systems. The 2 mods are cheap and beat the crap out of going piggy back or ECUs swap.
I don't know for sure but Id bet alot of those cracked manifolds, blown head gaskets, etc were on 80s running lean in part throttle.
When Im done it will be right one way or the other.
I climbed under and changed the fuel filter and added a banjo bolt with a shrader valve to monitor FP. I installed the F2025 FMU. It makes a difference adding fuel immediately in moderate throttle. AFRs drop to 12-13's but within seconds the ECU catches up and pulls fuel to get back to stoic. It would do the job probably just fine with a slower spooling turbo. This is below 3#. It never comes out of closed loop which is expected. The enricher will be necessary to manage the closed loop AFR below 5" of vacuum and into light boost. The enricher should arrive by next weekend.
too much work and hassle to go standalone.
Running HPTuner on my supercharged Tacoma now. It’s amazing having adjustment with one device. Now, the ecu on the 80 has to be replaced with a Haltech or something. I get that. I'm pretty sure we've had a discussion about Boomslang | Automotive Wire Harness Manufacturing Abilities and Services making a harness for the 1fz and Haltech.Are you sure about that? having multiple adjustment devices work and need to adjust independently is far more pain in the rear and God forbid your condition change. Standalone is one and done with all the setting managed centrally, as an engineer I absolutely HATE having disparate things work independently and I have to mickey mouse them together. That never goes well, centralize and standardize is the only way to get anything to work and make sure it continues to work.
