Turbo 3b overheating in the mountains
Discussion in '60-Series Wagons' started by rhah, Jul 17, 2017.
  1. rhah
    rhah
    82
    185
    Dec 23, 2010
    ottawa, kansas
    As the title says the turbo 3b is trying to completely melt down on us.
    Rad was redone by rad shop before swap 2k ago
    Electric fans
    X2 pushers, 1 puller
    New thermostat and rad cap this am
    Egt temps between 8-10k on the mountains
    Boost 10lbs and under.
    Speeds about 25-35 mph
    Rpm 2200-2700
    5 speed tranny and 33x10.5 stock gears
    No visable bubbles in rad after we reach normal operating temp
    Showed up early for the fjsummit to make sure all was well since it's not the flat plains of ks and we didn't have any troubles on the 900 mile drive till monarch pass, first big climb for it
  2. roma042987
    roma042987
    4,275
    Media:
    3
    Albums:
    1
    2,183
    Mar 30, 2011
    huntsville al
    If it's full of coolant and temp gauge is accurate sounds like you may have some head gasket issues. Is it puking coolant up yet?
  3. GLTHFJ60
    GLTHFJ60 Rum Runnin' SILVER Star
    22,504
    6,288
    Apr 18, 2005
    Durham, NC
    You're just working it hard man, they heat up in the hills. How hot did it get exactly?
    mel lowe and stevebradford like this.
  4. rhah
    rhah
    82
    185
    Dec 23, 2010
    ottawa, kansas
    Never hit the red but she wanted to.
    Puked coolant once but haven't since then
    I wish it was the case of over working but the gasser that is running with it isn't having these issues
  5. Tapage
    Tapage Club 4X4 Panamá SILVER Star
    22,944
    1,109
    Apr 4, 2003
    Panamá
    how old it's your t-stat ..?
    how you control your fans .?
    how much flow you really get with them through your rad . ?
    I'm using 4 core, all y cooling system has been rebuild by me consciously, ford contour fans, flex a lite controller, all fue y 2H it's capable of, 14 - 16 PSI of boost, water injection and if I want it it can go over 200F easily ..
    so how hot it is ..?
  6. GLTHFJ60
    22,504
    6,288
    Apr 18, 2005
    Durham, NC
    You're overworking your truck, plain and simple. The engine is producing more excess heat than can be shed by the cooling system. Just because another truck can do the hills fine at that speed doesn't mean yours can. Slow down 5 or 10 miles an hour and see if you have the same problem.
    Either your cooling system is no good or you're just pushing the engine too hard. Knowing what your actual temperature is would help. The dash gauge isn't much help.
    Drive slower till you figure it out.
    stevebradford likes this.
  7. d90rover
    d90rover
    33
    24
    Sep 25, 2006
    Gilbert, AZ
    There are only a few possibilities left that haven't already been addressed. The easiest is the water pump, is it in decent shape, moving enough volume through the system? Belt appears solid. Are you losing coolant, is the level staying constant? Any white smoke or residue at exhaust that would indicate a blown head gasket? Just a couple thoughts.
    Best
    Mikey
  8. cwwfj60
    cwwfj60
    1,014
    Media:
    1
    Albums:
    1
    237
    Dec 16, 2007
    San Antonio, Tx
    I'd suspect the reworked radiator...depending on how trust worthy the radiator shop is
  9. rhah
    rhah
    82
    185
    Dec 23, 2010
    ottawa, kansas
    Water pump replaced at time of swap.
    Manual control on fan, which is turned on when vehicle started
    New belts cap thermostat and coolant level staying constant.
    Exact temp I do not know more than our grand temp gauge
    Normal smoke for a diesel
    Wish slowing down were an option any slower and it would be going backwards. It should be able to cross the Rockies on 550 without overheating
    Guess I'm in denial about head gasket
    Thanks for input guys
  10. Tapage
    22,944
    1,109
    Apr 4, 2003
    Panamá
    let's think about this .. .
    Drive a brand new out of the plant BJ60 NA and then you will see what slow on hill means .. you adding turbo and possible more diesel are producing more output yes .. all happiness until the old IDI / precup design knock to your door .. cooling system in tip top shape was not meant to cool a turbo engine .. less with more fuel ..
    GLTHFJ60 likes this.
  11. POTATO LAUNCHER
    POTATO LAUNCHER TLCA #6928
    790
    1,468
    Nov 30, 2009
    Amarillo Tx.
    Whats the word man? Any issues on the trail?
  12. cruisedeisel
    cruisedeisel Toyota's for life
    1,553
    688
    Feb 5, 2009
    Courtenay, vancouver island
    I have a turbo 3b with 23 psi boost at 2700 rpm 4.10's and 35's. Stock cooling system. Fuel turned up 2.5 turns. The temperature starts to climb a little at 1050 degrees post turbo on my pyro when you are climbing mountain passes. Just so you can back off your foot a little. I pass people up mountain passes at 100-120kms pre hour. So there is most definitely something wrong with your cooling setup. I can drive all day at 15-18 psi without any coolant temperature spikes.
    It is possible that your truck isn't getting enough fuel? Turn up your fuel. Its sounds backwards but too much air and not enough fuel will create heat.
    Try taking the thermostat out and going for a heavy hill/mountain. If you don't like the idea of that just buy a new one.
    Maybe you need a coolant flush?
    Could be your rad is blocked or your engine block is?
    Why do have electric fans? The stock system works AWESOME!
    YOU ARE NOT OVER WORKING THAT ENGINE!!!
  13. GLTHFJ60
    22,504
    6,288
    Apr 18, 2005
    Durham, NC
    You've got that backwards man. That's how it works for gasoline engines, but for diesels, excess fuel causes excess heat.
  14. cruisedeisel
    1,553
    688
    Feb 5, 2009
  15. cruisedeisel
    1,553
    688
    Feb 5, 2009
    Yes too much fuel does cause excess heat but so does too little.
  16. cruisedeisel
    1,553
    688
    Feb 5, 2009
    Have you turned up your fuel at all?
  17. GLTHFJ60
    22,504
    6,288
    Apr 18, 2005
    Durham, NC
    No, what you said is wrong in the diesel context. Too little fuel makes GASOLINE engines run hot, but it makes DIESEL engines run cool. Your cited article, a software programmers website by the way, explains in the context of gasoline engines.
    If you want to test your theory, go turn down the fuel in your 3B all the way and see if your temps are cooler. Hint, they will be.
  18. cruisedeisel
    1,553
    688
    Feb 5, 2009
    ok, after searching for the last 20 minutes i am not finding any more info on this. I do suck at internet searches but I was under the impression when an engine is not tuned properly. Too much or not enough fuel will cause over heating. So I may be wrong about fuel being an issue.
    A 3b-t can handle mountain passes without over heating. If you havn't turned up your fuel, you might want to anyways. Like I said before the stock cooling system works great as long as its clear of debris.
  19. GLTHFJ60
    22,504
    6,288
    Apr 18, 2005
    Durham, NC
    That is good info. It was suggested before, but with your input, I'm going to have to agree that something is wrong with the cooling system.
  20. Cruising Canuck
    Cruising Canuck
    441
    Media:
    10
    Albums:
    1
    311
    May 22, 2012
    Ontario, Canada
    It does sound like their is something wrong with the cooling system. Replace the t-stat again because it's easy.
    Our trucks are setup identically. Except for the fans.
    Why did you go to electric fans? They are inferior in my opinion.
    But I bet the radiator is the problem. I bought a champion aluminum rad. It's a good piece of kit for the price.
    If I were you I would replace the t-stat, then the radiator and then fans for a clutch type.
    Good luck.
    And glthfj60 is absolutely correct about fuel temperatures in diesels. It was hard for me to wrap my head around it, but in diesels more fuel equals more heat. Less fuel equals less heat.
    You need a turbo to pump more air into the engine to bring down those egt's
