Tundra/Sequoia Steel Wheels (1 Viewer)
Texas
Anyone tried to fit the factory 16'' steelies from a tundra? I know there 16x7, 6 on 5.5, but will they fit w/o spacers? I've searched this to death, but can't find any info about it.
I haven't tried it but from what I can guess, they should fit fine. I'm looking at getting some as a cheap alternative to the 16x6 steelies.
Yea i do. I just put a set of tundra/tacoma steel wheels on. At first
i thought they would be ok but when i put one on it hit the tie rod
end ever so slightly, but just enough rub on the rim and the rubber
boot. I then got a set of 1/4" spacers and put them on and that fixed
it. But all i had heard up to that point was that 16's would work without
them but not so after first hand experience. So my advice would be to
put them on and see for yourself but dont be suprised if you will need
the spacers....good luck
for me the spacers really arent a issue. there still is
plenty of lug stud and it doesnt make the tire stick out
that much at all. I will post a pick tonite when i get home
of it with the new tires and mirrors on it...
:eek: My mistake, sorry. I'm not accustomed to looking at older posts for newer material. Thanks for the pics ;)
and i meant to post it right and clicked the wrong thread
hmmmmm; must be the tires; I put on 16 Taco wheels with tires on our 85 fj 60 w/o any spacers or mods and there is no rubbing at all; tires though are light truck 235/75/16s;
Lou
Taco/Tundra wheels
Wife just got in with the fj60 with taco wheels and I want to correct the size; they are 245/75/16s.......did not use spacers and have had no problems with clearance or rubbing although it is tight, we have had them on for about 5000 miles and got them with about 200 miles on them;
Lou
Thanks for the input. n2666s, what year/model are those off of. They look good on the 60.
I've found a pair on craigslist from and 06 tundra, want to put some 235/85/16's on them and paint them black. We'll see how they turn out and I'll post some pics when there done.
The only thing i can think of in my case as why they hit is that
my springs are almost horizontal otherwise theres no reason that
they wouldnt. I have 265/70/16 dunlops but dont think tire size
matters much.
they were off a 2006 Tacoma that the owner decided to put huge mudders on and lost control of his Taco on a slick road ended up totaling it and over
2000 $ worth of wheels and tires.......that he had only had on for less than ONE day.........so, no Taco but 4 new tires; well nearly new with about 200 miles on them and a wife bitching at him cause of the screwup........; now the wheels are on our fj60 and we have put quite a few miles on them.......they are 245/75/16s and they look a lot narrower than the Dunlops <notagp_afj55> has on his 60; hope this info helps;
Lou
P.S. for
notagp_afj55 ; why are your springs nearly horizontal?, does it have high milage?; ours is 103,000 miles
Lou
The truck has 216,000 on it and i have no history on what the
PO did with it, by the looks of it no rust and all i think it was
just a mall cruiser for someone here in Portland. But all of
that will be fixed in a couple of weeks as i have new springs
new to me anyway coming and hope to get my stock arch
back.
the clearences are tight BUT there has been no rubbing at all with several thousand miles on it. there is another local fj 60 with 230,000+ miles on it with stock Toyota 16 inchers <canadian>and 265 or 275/16/85s on it without any rubbing and those tires are taller than ours...hope this helps :)
Lou
NOTICE!!; finally got the truck from the wife and did some light wheeling this weekend........the right tire did rub on the steering box .............not the wheel, only the tire; I will have to put spacers on the front; just wanted to share this with Y'all because we /she had only put in freeway time on it since she snagged it from me but with "light" wheeling the right tire will rub with this setup and probably both sides will if pushed hard; believe 1/2 inch spacers will be the solution; on the other local fj60 it has canadian fj60 16 inchers and NO rubbing!
Lou
