- Year
- 2000
- Vehicle Model
- LX470
- Location
- United States
2000 Lexus LX470 – VIN: JT6HT00WXY0100169 - $13,000 OBO
A well-sorted truck that runs and drives great, needs nothing. I recently returned from a 2500 mile round trip to Colorado and it performed flawlessly even at high elevations. 254k miles, rust-free Texas/Oklahoma truck - I am the third owner, the second owner owned it for 16 years. I purchased it in March 2019 from Fort Worth, Texas. Tires still look new. AC is ice cold. AHC suspension converted to a standard suspension. Third rows seats are in perfect condition & factory running boards and hardware included. Clean title in hand. No Accidents. Timing belt and water pump were done 11-17-2015 @ 195,793.
Fog Lamps do not work and has a few minor door dings and scratches on the top of the spoiler.
Approx. $6k in recent maintenance items:
238,500 - 05/07/2019:
Upper control arms and ball joints
Front and rear sway bar end links
Front sway bar bushings
Old Man Emu Suspension – 1.5” Medium
Infamous heater tee’s replaced with metal tee’s
Denso Alternator
Interstate Battery
239,000 - 6/24/19
285/75/16 falken wildpeak at3w
Interior LED Lighting
New Steering Wheel
Clock Spring Replaced
239,500
Front differential bushings (3)
Transfer case fluid (Lucas 75w90)
Front Differential (Lucas 75w90)
Rear Differential Fluid (Lucas 75w90)
Denso Starter
Greased Drivelines
243,855
Valve cover gaskets
Front End Wheel Alignment
Lexus OEM LED third brake light in the spoiler
LED reverse lights
Oil change - 5w30 mobile1 high mileage full synthetic:
Oil Filter M1-102A
Tire rotation and balance
OEM CV axle shafts (both)
Front wheel bearings Replaced
Front and Rear Power Stop Drilled and Slotted Rotors and new ceramic pads
248,700 - 03/06/20
Power steering fluid flush (Dexron III ATF)
249,100 - 03/26/20
OEM steering rack w/ superpoly bushings
Sankei 555 lower ball joints
Sankei 555 inner and outer tie-rod ends
Front end Alignment
249,700
Cleaned throttle body
Cleaned MAF
Engine Air Filter
Cabin Air Filter
Greased Drivelines
249,800 – SuperPoly Pro Bushings
Rear upper trail arm bushings
Rear lower trail arm bushings
Rear panhard bar bushings
250,540
Toyota Fuel filter
251,000
Replace wheel locks with standard lug nuts
252,000
Parking Brake Adjustment
Front Differential Fluid 1.8qts (Lucas 75w90)
Transfer Case Fluid 1.4qts (Lucas 75w90)
Contact Jon 918-852-2555
Email: jangelo74@gmail.com
- OME-303001 Front Torsion Bars
- OME-60000 x2 Front Nitro Charger Sport Shocks
- OME-2865 Rear Medium Load Springs
- OME-60002 x2 Rear Nitro Charger Sport Shocks
- SLEE Diff Drop Kit
Denso Alternator
Interstate Battery
239,000 - 6/24/19
New Steering Wheel
239,500
Denso Starter
Greased Drivelines
243,855
Valve cover gaskets
LED reverse lights
Oil Filter M1-102A
- 241,100
- 246,222 - 01/29/20
- 250,540 - 05/10/20
- 244,300
- 249,615
- 254,300
248,700 - 03/06/20
249,100 - 03/26/20
Front end Alignment
249,700
Cleaned MAF
Engine Air Filter
Cabin Air Filter
Greased Drivelines
250,540
Toyota Fuel filter
251,000
252,000
