Trying to find a AC pressure switch HDJ80
Decatur GA
So the part #8864560010 is discontinued. There are two options which are 8******0020, and 0030. I can get 0030 but I cannot get enough info to find out if the switch is the correct LP switch with the right rating. I would appreciate any info. Also, I didn't know if it was the same one used for the F80 or not.
So while the 030 has the same plug, it will not cross reference to the same application as the 010. While they both have a low limit of .196 Mpa, the 010 has a high off pressure of 2.7 Mpa and the 030 has 3.1 Mpa, so you may overpressure the system using the 030. You can try getting a Honda Passport switch from Honda, part number 8973669640, which should be the same switch and should be available still from Honda.
