Hi folks,
Just wondered if someone would recognize the cause of this right off the bat. Normally, truck seems to be running fine with no fuel delivery issues. However, I sometimes have a problem starting it. It will start up and then immediately die as if for lack of fuel. After a few tries and pumping the gas pedal it seems to catch as if fuel finally arrived in sufficient amount. Also, and I feel this is related, sometimes the truck will start fine and I will start driving down the road and suddenly the truck will start dying or coughing, again as if starved for fuel. After babying it a bit or pulling over and restarting…it runs again with no problem. Might this be a simple fuel filter that should be changed (can't remember the last time I did that and truck has been sitting for years) or does it sound like the fuel pump? I know, not a lot to go on but just though I'd throw it out there before I do something dumb. By the way, I have a Weber carb…no gunk in the little screen there, either.
Thank you.
Thank you.
