When I bought my 80 the previous owner had purchased some customized depo lights with HID projector low beams (lense and bulb details are unknown) and halogen high beams. I pulled the grill and headlights the other day to remove the peeling plastidip from all things chrome and repainted with black bedliner.
I took pictures of the connections before disconnecting. When I put everything back together this weekend, my low beams don't light up. I've got tail lights, corner running lights, and high beams, but no low beams (high beams have no ballast, just a fancy bulb).
What I found strange was that both are not working. If one went out, I would suspect a bad ballast or bulb, but both were working fine before I pulled the headlight assemblies and neither worked after.
I didn't remove or handle the bulbs at all, and I kept the headlight assemblies and ballasts indoors and away from dust and moisture.
So far I have tried reversing the relays and also plugging an OEM bulb in the connector that the ballast gets power from. When the relays were reversed, I still get high beams but nothing from low beams. When I connect the OEM bulb, it lights up.
I did use dielectric grease on the connections (noticed that one connector had some corrosion and periodically one light would fail to light up). Other than that, so far as I can tell I have assembled everything just as it was before.
Anybody have a suggestion on what to check next? I'm hesitant to put a multimeter on the ballast out of fear of frying it....
