890man
Ok, it started after a weekend trip to Hollister, Ca. On Sunday before heading home I hit the trail to do a few things I had done the day before. I was having a great time until I was doing a little section at the bottom of truck hill that I had done twice the day before with no problems. This section really twists a truck up lifting tires . Right from the start I couldnt turn left. I could turn right and bring it back to center. I was able to get a little left but not enough to do much. I had to reverse and try again multiple times to get lined up right. Something I did not have to do the day before. By the time I knew I was having a serious problem I was in the middle of the trickiest section.(Wheel in the air and real tippy) I was able to get through without laying it on its side and take the bypass. I checked for damage, none, fluid level, good. While moving all is well. While stopped I can only turn left about half the normal distance. It starts feeling good then becomes almost like manual steering. If I start moving, the resistance goes away and turns fine. Turning right to the stop is easy while stopped. I drove the hundred miles home but the problem has not changed. I did search but if you guys could help diagnose or help point me in the right direction, I would appreciate it.
Thanks, Travis
Thanks, Travis
