Trying to remove the fuel delivery rail, I have everything off, but cannot seem to loosen the bolt that runs from the fuel pump to the #2 pipe behind the valve cover, near the #6 cylinder
The manual appears to show this bolt as the thing to disconnect
This is a close up photo of this from the manual
Manual just says this
REMOVE N0.1 FUEL PIPE AND N0.2 FUEL PIPE WITH ENGINE HANGER
I am trying a 19mm and 14mm wrench but the 14mm bolt is gonna round off if i keep going.
Is this reverse threaded, or am i removing the wrong part or is there an easier spot? Also nearly impossible to work in this spot at the rear of the engine in the middle
- (a) Disconnect the fuel and vacuum hoses.
- (b) Remove the pulsation damper and two gaskets.
- (c) Remove the two bolts and No.2 fuel pipe with en- gine hanger.
