So, I just replaced all my bushings in the front and back leaf springs, shackles and hangers…something I had talked about in a previous post. My front end is a bit mangled due to a rough life but after some four letter words I got it done. The real problem was with the hangers. That was very difficult to line up the holes on both sides in order to slip the bolt through and more to the point have it emerge on the other side. I suppose that is to be expected due to my challenged front end but I'm wondering if other folks had this experience and if so are there any tricks to it?
Also: are the hangers normally of such a width that the leaf spring plus the bushings almost doesn't fit in? I had a hell of a time with it and in fact my new bushing is half chewed off on one side of the flange as it ripped in the process. It seems the hanger could have been 2 mm wider and all would have been good. Did this perhaps happen from over tightening the bolt and squeezing the hanger? I only have the rear hangers left to do and I really really don't want to run into the same troubles. Anybody have input on this? Is there some way for a backyard mechanic to enlarge that gap a bit?
Thanks all. I thought my rear springs were super stiff Ranchos but now that I have the new bushings in at least the shackles it bounces up and down nicely. Yup, the bushings were frozen.
Cheers, Sproggy
Cheers, Sproggy
