Trouble codes 25 and 26...any one?
mmw68
CruiserCrap.com - pimping crap for your cruiser!
Supporting Vendor
Austin, Texas
Website
store.cruisercrap.com
OK search around but found no disscussion on this.
Iam getting these codes, back to back. . Anyone know what could casue these codes.. O2 censor maybe? They are the only thing left, I have not changed or tuned.
code 25
Air/Fuel ratio lean Malfunction
(1) When air-fuel ratio feedback compensation value or adaptive control value continues at the upper (lean) or lower (rich) limit.%#@& (2) When air-fuel ratio feedback compensation value or adaptive control value feedback frequency is abnormally high during feedback condition.%#@&
code 26
Air/Fuel ratio rich Malfunction
NOTE: For condition (2), neither a lean (Code #25) nor a rich (Code #26) diagnosis is displayed consecutively.
I don't think so, as the the O2 sensors job is to trim the fuel/air ratio over a fairly narrow range. I bet you have already been made aware of the FPR issues, haven't you and have you changed the FPR yet? Are you sure there isn't any moisture in the fuel system? One other thing, the oil companies are probably switching from winter gas to summer formulas about now and that can mess things up too.
A 25 and a 26 code together IS the sign of a bad O2 sensor. That's the ly thing I have encountered that will give you both of these codes.
They're cheap. If it is not a new(ish) part already, then replace it if in doubt. They wear out.
Mark...
