Just got my trollhole installed. It all went easy except for my fuel cut solenoid being left off on accident.
Here's where I stand :
-air cleaner vacuum lines and ports are capped where needed. Found a pvc vacuum leak that was quickly fixed.
-AC idle up installed.
I'm referencing the attached diagram for setting the idle, but my actron remote rpm gauge is dead right out of the box. So I'm going to the factory tach.
I started at 2 turns out on the idle mixture, kept on turning til the idle wouldn't raise any more. The I used with inner most idle screw to get it to about 750rpm hot idle. Set the AC idle up and it's right at 1000 AC on.
The problem is that I get a very bad stumble off idle. The truck bogs off idle til 2000 and then pulls out of the bog nicely.
I figured that there is a sweet spot in the idle mixture screw that either makes the off idle transition rich or lean. It's that point that I've not reached yet. I haven't tried the idle mixture screw extremely out but so far 1st gear is almost completely useless. I had my factory Aisin set better than the trollhole.
Is there something else that could have caused this stumble that in maybe did in the install? I don't follow what could be that off. I even tried setting the idle mixture screw and idle screw to about the same point that the aisin that came off was at and it didn't help the stumble.
Do I need to call Marshall tomorrow is is there something else going on?
