Triple Locked Locker Actuator Maintenance
Idaho
Is there maintenance that needs to be performed on the actuator to get the maximum life out of them? I know the wiring components are no longer in production. Is there a common failure point on wiring that I should start trying to source a spare to keep on hand?
Take it down (10mm Bolts) and Look inside. Itr should be Apparent what needs done and if Corrosion is Present.
@danmcph : Try a search on this forum for posts/threads by member Landtank and use the terms rebuild actuator
I have this on my todo list and have these two links saved for when I find the time.
