Tricks for removing 28 year old brake hose?
Morrison Formation
Need to remove the frame-axle rear brake hose. That thing is seriously buggered on there. Use a 16mm right? Anyway, any tricks for removing this? I almost started breaking things before I decided to stop last night.
spotcruiser
Geezer
Western WA
Soak it with plenty of PB Blaster, Kroil, or equivalent prior to the work. Flare nut wreches help, unless the flats are all torn up. Sometimes it helps to work it in both directions, slowly and gently.
PNW
Use a tubing wrench or flarenut wrench (same thing) if it's not rounded. If it is rounded about the only chance would be to carefully grab it with a pair of small vicegrips. Small back and forth works sometimes. Be patient with it.
Pepperell MA
Given the cheap cost of new parts I'd just break it to get it outa the way of the new stuff. Cut the hard line where it's clean enough to join a new piece of line in and go from there...
Nick
Between Here and There
come on guys he's in arizona not NY... couple shots of PB and it should come right off if it's always been an az rig. My colorado ones i've never had a problem with after a couple days of hitting it with PB and using a flare wrench.
Morrison Formation
It was a CO truck for much of its life, AZ the last few years to permanently preserve its condition :). Body isn't great but frame et cetera is very good.
I was replacing the front & rear with new longer hosing. I need to go find a 16mm flare. Problem is I start bending the mounting frame bracket when I turn it. It's been soaking in penetrating oil for a while now, tonight'll be the night.
Oh year now I remember, the soft line to the hard on the ps side frame for the rear axle. That one is always a biotch.. Try to hold the other end of it so it doesn't twist. might try some heat too.
Morrison Formation
Uhh, no not sure it ain't 17mm! Unless it's been previously been `trimmed' by the PO. 17mm open-end seemed to be too big.
Can anyone clarify?
AlaskanWheeler
If your going to replace the hose; I would cut the hose so I could use a regular socket to remove it. That way you get more surface area on the nut and less chance of rounding the head.
Gumby
Supamod
s-Moderator
Knee deep in hookers and gin
try a good quality 17mm line wrench. An open end is never going to get it.
if you are going to destroy it, use a pair of vise grips. It won't always be reusable after that, but I often have success if i don't care about that.
Morrison Formation
Just picked up a 17mm flare end today. Tonight I'll give it a shot. I don't care about the hose really, but only if it is REALLY stuck then I can't drive it at all, so want my worst case scenario safe.
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
