I dropped my coolant, have to flush and refill before winter gets here. Any tips to avoid getting an airbubble in the system? I remember something about running it while refilling it and having the nose up...? Cant remember.
NocalFJ60 said:Yeah drive up on some ramps with the with the passenger side higher than the drivers side so the radiator inlet is higher than everything else. Turn on the heater on high with the back on too. You can bouce the truck to help the bubble come out faster.
hullendersauce said:oh s***. what happens if you dont do that?
hammer1 said:ive put a little peice of 3/8 hose through the fill cap, and into the body of the rad.
that way , i can use a funnel , and not have the burping issue.
NocalFJ60 said:There is just the chance air pockets are in the cooling system. The air pockets do not allow cooling of the wall there so you get hot spots.
hullendersauce said:what do "hot spots" do? should i flush and fill again? about a month ago, before winter hit, i wanted to flush my radiator, and refill. well, i did exactly what the bottle said. but i just threw a hose on it, and filled it throught the top of the radiator. i ran it for awhile, and then topped off my reservoir. should i go back and drain it again??? i just dumped a crap load of $ into it, hoping it would get me throught the winter ok. i dont need any unnecessary problems with the upcomming winter. -other sean
