Nope that’s the A440/A442.
Actually it is none of them wives tail, there is no known proof of any of the Asin 440/442 343 used in a bus
$1,200 was for a valve body modification, not a throttle body.
@richardlillard1 It has better gearing on 1st, better 5th (has five gears instead of four as in the A442F) and gives you faster shifts
I guess it’s not actually a transit bus. But Dyna’s and Coasters. Although I do need to correct my statement. I guess the coaster did get A343’s, according to Beno. But, I’m definitely no authority so... meh.
I looked at the Compushift and it runs you about $1500 with no display . The Microsquirt is about $400 and would take some, but not a ton of work@scottryana It can be done on mine, not sure about yours...1HZ...1HD-T...1HD-FT and 1HD-FTe share the same block (basically) over here A750F came with 1HD-FTe, so bellhousing should work from my A442F to the A750F...so now is a matter of computer...easy done when looking for it...go to COMPUSHIFT Sport and Pro and buy it...then just use the thing
I thought the 442 was a bus and then the 343 is in some short bus![]()
They make all kinds of different sizes of coasters. It wasn’t until I read one of Benos posts from his factory tour that I saw the A343 part. First time I’d heard that. But yeah... the others are common knowledge. Evidently even 22r’s were used.
I get to drive both on a regular (but unfortunately not frequent) basis. Both trucks with S/C and low TC gears.So I’ve been trying to figure out which one is better.
Typically when a manufacturer changes its for the better but some swear by the heavy duty a442 claiming it’s indestructible and therefore the better of the two. Then I’ve heard the 343 argument that it is lighter and robs less power from the 4.5 and is therefore smoother with a much better throttle response.
What say ye, fellow mudderz?
My A442 has 2nd gear start...I get to drive both on a regular (but unfortunately not frequent) basis. Both trucks with S/C and low TC gears.
In low range, the 1-2 upshift of the A442 will try and snap your neck. 2nd gear start on the A343 for the win.
Do you read the thread before flippantly commenting? He was responding to someone saying the A343 was better because it had 2nd start.the A343F does too![]()
Shouldn't have posted in a bench racing thread anyways... carry on.
