transmission transfer case spacers
Trying to get my 78 back together and it's been a while since I took it apart. And I apparently didn't take enough pics. Attached pic shows 2 spacers on the output shaft. 2 different diameters. I've also searched mud and looked at some various parts diagrams and am confused.
Do both go on the output shaft and if so is this the correct order.
Thanks in advance.
lets try this again. pic attached.
Sorry John, not this time. First spacer spans the thickness of the adapter plate behind the trans. The second MAY be the PTO spacer. Or it could be the tailshaft spacer behind the input bearing. Have to see those two side by side to tell.
The factory H41/2 transmissions use a cast "adapter" that joins the factory transfer case to the rear of the transmission.
There is a "gear stop" or "spacer" that fits onto the output shaft of the transmission against the rear output bearing of the transmission and positions the transfer case input gear away from the adapter and front portion of the transfer case and aligns the transfer case input gear with the idler gear in the transfer case.
It would appear to me that the larger diameter spacer pictured next to the transmission output bearing would, in fact, be in the correct location. This "spacer" or "gear stop" is significantly different than the "spacers" found to replace the PTO gear inside the case, or the one on the very end of the transmission output shaft, under the six bolt, rear PTO cone cover.
I know this is an old thread. Does anyone sell these spacers? I am working on 4 speed to 3 speed transfer case and need the spacers. Thanks in advance
In this picture from the H41/Orion thread in the FAQ, you can see the adapter plate and the gear stop/spacer...
spacer001-jpg.119304
dowels02-jpg.119306
looking at this photo, where does the t case front output seal go? Because doesn't it go behind the spacer in the ‘adapter plate’ ?
Have been in the process of putting my t case back on and have been trying to figure this out.
If you are referring to the t case input shaft seal, it is barely visible in the pics you posted, left side second pic, that is where it goes.
I was referring to this seal, not the seal in the t case.
Excuse my ignorance, not familiar with this t case.
Does the spring side of the seal go toward the transmission?
That seal goes on the front output of the t case, where the flange goes for the front driveshaft.
