Hey guys,
My '04 LX has developed some odd behavior in 1st gear. When moving from a stop or shifting in to D, the transmission seems to slip and catch in 1st gear, ie requires more throttle/rpms to get going than would be normal. Once it catches it behaves fine and all other gears are fine. Thinking it might be fluid level or condition, I just did a full fluid replacement with Aisin WS, got it to temp and set the level, which appears to have had no effect, though it was definitely due.
One odd thing I just noticed is that it does NOT do the same behavior when put in to L. If I run through all the gears manually it's totally fine. This does indicate that it's less likely to be something mechanical in the trans, but would this be true if the problem was a shift solenoid?
Thanks for the help.
