Transmission PTO
Discussion in '40- & 55-Series Tech' started by stephen, Jul 14, 2005.
  1. stephen
    stephen
    81
    May 4, 2005
    why is the pto mounted on the transmision face rear wards
  2. bj40man
    bj40man
    213
    12
    Sep 17, 2002
    I will try to help you out from what I have seen.
    My BJ40 has a H41 4 speed transmission with a cover where the PTO mounts. My rig is a 1975 model year. Iwas courious about the same thing a while back and did some research myself. What I found is that at that time the mentioned H41 was also used on the Dyna truck (as well as the B engine) and only engines & trannies from Dyna trucks had the PTO installed, for the LC has its design on the transfer case. This is all I can say. I am also interested on finding this out, for I can easily get those PTOs around here.
    regards
