I have a leak that appears to be transmission fluid. The leak is noticeable where the transmission and engine meet. It is in the same are that a rear main seal leak would be evident. However, it appears to be tranny fluid. Any thought on this?
Note: This feature currently requires accessing the site using the built-in Safari browser.
Thanks so much for your responses. It is coming from the weep hole in the bellhousing. Was actually a qt low of fluid, so not overfilled. Any negative long term effects from using at-205 in these transmissions?Make sure it is coming from bell housing weep hole. If transmission is over filled it can cause leaks. You can try AT-205 in transmission. If leak continues, you'll need to pull transmission.
probably input shaft seal, could be the pump o-ring but that's not usually a leak point. either way you would have to drop the trans so might as well do the rear main at the same time
Did you ever figure this out, my sons 98Thanks so much for your responses. It is coming from the weep hole in the bellhousing. Was actually a qt low of fluid, so not overfilled. Any negative long term effects from using at-205 in these transmissions?
