Transmission issue (1 Viewer)
Hi All,I got the the dealership grease the Driveshaft. The problem pertained so I did it myself just to be sure they did it right.( Greased Ujoints and Slip Yokes).. But the problem still exists. :(
Any suggestions on my next step?
When was the last time you had the front bearings repacked. Often times if they haven't been maintained properly the front cvs/hubs can be worn created slack in the driveline.
My car jerks as soon as I step on the gas and then it’s runs smooth. It feels to me like it’s a transmission issue.
Did anyone face this issue with their 100 LC?
And does anyone know a mechanic in Massachusetts? Worcester, Shrewsbury, Framingham areas?
I do not think that you have a transmission problem as look as you did not mess with it or a ATF fluid, what with your work on what did you change? new spark plugs? or still, using original?
So basically i bought this car like about two months back. And it was fien for the forst two weeks. and it started giving me this problem. Didnt go bad on a pot hole, or hit anything, or drive bad. The usual normal driving. So not really sure if anything like the spark plugs or stuff was changed before i bought it.
Hmm I bought this car two months ago and the issue started two weeks after i bought it. So no idea about when or even if the front bearings were repacked.
Hi,
Please let me know if you manage to fix this, i'm facing exactly the same issue. Car Jerks while stepping on the gas, and while changing from R-N-D. Didnt notice any jerk when gear changes while driving. I have a 2006 model with 466550km
