transmission fluid change
Find a place that has a "transmission fluid exchange machine" DON'T LET THEM FLUSH YOUR TRANSMISSION!!! take in around 18 quarts of Mobil synthetic ATF and have your old fluid exchanged with the new Mobil synthetic ATF. You now should be good for another 60K miles. Should cost you around $120 for the fluid and the exchange process. I did this on my FZJ80 at 60K and 120K.
Hi Pitbull,
Does doing the transmission exchange include taking the pan off and cleaning the screen as well or is that a seperate process?
Hi Pitbull,
No. I had the only "award winning" Toyota dealership in the Rocky Mtn region do mine recently. They pull the ATF cooler input/output hoses and connect those to a machine. The machine has one large container with the new Toyota-brand ATF, one empty container. Tech said they use 16 qts of new fluid. They then run the engine until the new fluid has entered the transmission and old fluid is in the previously empty resevoir. They DO NOT drop the tranny pan, nor do they remove the drain bolt. They also put some kind of additive in the ATF to 'make it shift smoother,' said it was the norm. The 5 speed shifts just as smoothly after the exchange as before, so I guess they did it correctly.
Did you put WS ATF in your 03? Additive? I don't like them adding anything to the ATF, but I would hope a Toyota dealer would never put a "cleaner" in the automatic transmission.
So I did the dry clean paper test of my transmission fluid. There is an outer ring that looks a bit darker than the middle once it dries. It does not look extremly dark though.
I think this is what I will do:
1. Drop the pan the first time and clean the screen.
2. Do a drain and fill in 5k intervals until the "drip test" shows virtually no outside darker ring.
It seems to me that, with previous maintenance records not available, this is the least risky way to go about it, instead of doing either the fluid exchange or the flush (a flush - I will not do at all).
I had the same look with my 95 LC at about 60K miles. I did a fluid exchange using Mobil synthetic transmission fluid and 18 quarts of fluid in the exchange to make sure I got all new fluid in the transmission and torque converter. It was still nice and pink at 130K miles when I sold it and it always shifted like new. The exchange is less hassle and you can buy the Mobil synthetic ATF in bulk so the cost is not bad at all. I stood there and watched the entire process to make sure they used all my fluid and did not put a cleaner in the transmission.
So this is my deduction:
Transmission oil flush : a No No
Transmission oil exchange : good option
Drain and fill every 15K miles : good option
Dropping pan/cleaning screen : good option
If you start with a new vehicle, the best thing seems to be to do a drain and fill every 15k miles.
If you bought your vehicle used with previous mainteance unknown:
- if the transmission oil drip test shows the oil as being relatively okay (no dark ring in the paper when the dripped oil dries), an exchange is okay.
- if the drip test shows a significant dark ring, an exchange might not be enough. May have to drop the pan and clean the screen AND do a complete fluid exchange.
If going from current oil (any) to synthetic, either a gradual drain and fill several times or a complete exchange are both okay.
Notes:
Drip Test simply refers to dripping the tranny oil from the dipstick into a clean white paper, letting it dry and checking if an outer ring forms that is darker than the inner ring. The color of the oil should be pink.
To do a drain and fill: The drain plug can be found on the transmission pan. The fill is done through the dipstick.
Fluid Exchange refers to completely changing all the transmission oil with the new oil. Make sure that
1. They are not flushing the transmission oil.
2. They are not using any additives or cleaners.
3. You probably want to use synthetic ATF.
4. A complete fluid exchange will use about 16 - 18 quarts of oil. Make sure that they use all of this oil.
You got it covered
No, it uses Toyota type T-IV (I think it's made by Mobil). No cleaner. Tech said the additive is something to smoothen the shifts. I noticed it on the invoice and asked. It seems to drive the same as before, no issues. Only time will tell. At least I had a toyota dealer do the work and have the receipts, so the CPO warranty should hold. Oh, ya, the tech who did the work was a lexus tech and the tech at the dealer who was most familiar with the 100. BTW, the old fluid was still nice and red, no dark tint, no burnt odor. IIRC, the owner's manual doesn't say you need to change the ATF at 30/60K unless you tow.
There is no need to drop the pan, the screen self cleans when you drain the fluid, as it flows the opposite direction. IF you are concerned about the current condition of the fluid, do a drain and fill at each oil change for 2-3 times, then do it every 30k.
Hey Jim,
Could you please dig out your receipt for the work and tell me the description, part number and cost of the additive they put in your 5 speed please. I have 20 litres T-IV sitting in the garage and may do mine this weekend, but I am curious about the additive. I wont use any as I would not be able to get any I expect, and would like to research it further, but I am interested.
Cary,
So the only reason to drop the pan is to see for yourself if there are any large metal shavings there? That there is no need to drop it and clean the screen as long as you do a drain and fill............
The screen self-cleaning when you do a drain and fill - does that hold true when doing a complete exchange as well? I would assume so.
Thanks.
Any shavings will come out the drain plug, including large ones. The self cleaning may not happen when doing an exchange because the fluid is being drawn through the screen, not out of it.
DO NOT under any conditions put an additive in your transmission fluid. I don't care what you dealer does. Transmission fluids have become very specific, especially in newer cars (the Toyota Specific Fluid). Any additive will effect the properties of the transmission fluid that was selected for its exact properties. Many well informed people believe a large number of failures in transmissions are as a direct result of additives/flushes/other fluids being used during the fluid exchange.
Finally, do not allow a quick lube place to change your fluid. In the case of newer trannies like those that call for the T-IV fluid, they will use Dextron III with an "additive that makes the fluid meet Toyota's specs." The problem is it doesn't, and by the time your tranny fails down the road, they will say, "not our problem." I have a friend that didn't listen to my advice about this with an Acura (requires specific fluid) and it cost him $4500.
