I’m having an issue with my transmission. When I’m slowing down to a stop or to a very slow speed from 20 mph+, my transmission has an issue downshifting and it feels like the transmission is in neutral when I try to accelerate. Eventually, it will kick into gear (the higher I'm revving, the harder it slams into gear) but sometimes it takes 2-3 seconds and it's just in neutral until it does.
Other than this problem the transmission works perfectly.
The fluid looks clean and the fluid level reads correctly on the dipstick both, hot and cold. The lx has 200k, but it’s pretty new to me and I’m not sure of the history. It isn’t throwing any codes. Some of the threads I’ve read may point to shift solenoids, but wouldn’t there be check engine codes if the solenoids were failing (that’s what the transmission shop thought).
I’ve taken it to a couple of shops including a transmission shop. The transmission shop recommended replacing the transmission to fix the problem. None of the mechanics have really had any solid ideas as to what could be causing the issue.
Obviously, if there is a way to fix the problem without replacing the transmission that would be ideal, so just want to exhaust all options before opting for a replacement.
Thanks in advance for any help!
