Transmission Cooler for HDJ81
Calgary, Alberta - Canada
I was wondering if anyone has installed a transmission cooler for an HDJ81. Could you please post your setup, what make, part no. , where did you buy it from and if you have any pictures/instructions for the setup that'll be great too..
:cheers:
Cruisin'
Out in the shop, building something cool!
Chilliwack, BC
I also have the Tru-cool. Been very happy with it. I don't have any good pics, but I got the second biggest one (I think its about 8" x 11" and it fits nicely in front of the rad on the left side.
I just wish I had installed the trans temp guage before the cooler, not the other way around!!!
-Jason
Abby
Jason, did you buy the cooler and gauge locally or online. I still have to put one in my wife's. Was also thinking about adding an aux fluid filter as well.
Cruisin'
Chilliwack, BC
I got the cooler through Gregg's distributing. I don't know where their retail outlet is, since we deal with them at work.
The guage came form Piers Diesel in Pt Kells. It was only about $65. Isspro with a full sweep. (many trans guages are only 90 deg sweep)
-Jason
Abby
-Jason
I know where Gregg's is. They are just off of 200th on 96th (19632 96 Avenue). They also have a good stock of 24V bulbs. I have yet to make it in there because they are a Mon-Fri and only open until 5:00 PM. Holidays are coming up next week so i should be able to get in there. Thx for the info
Vancouver, Canada
They specify it's for 5/16 or 3/8" cooler lines so I'm assuming they're supplying hose barb fittings for each. Either way, a quick trip to the hardware store and you can get whatever you need. You're just going to cut the rubber hose near your radiator and run it in series there.
I'm just going to measure and see if I need the small one or if I can fit the medium one in there. My liquid-air intercooler core and water pump take up half the space already...
Abby
For the guys who are using the Tru-Cool, do you know the model number?
I went to their website and there are numerous models and no application guide.. Did you need any extra fittings or is it a bolt-on installation??
Trucool LPD Heavy Duty transmission coolers: transmissioncoolers.us
Thanks..
Landcrusher80, according to the link in his post, got this one: Tru-Cool LPD, thick cooler & standard installation kit: transmissioncoolers.us
Interesting to see it a fair bit cheaper on the site you found than fleebay. I can't compare the price with Gregg's. Seems their on-line cat is out of order.
yes i have the tanden 8x11 on the upper side with a supra inter cooler bellow work better but i also removed my ac rad being i never used ac
