transfercase
Discussion in '60-Series Wagons' started by cruiser88, Aug 26, 2006.
  1. cruiser88
    cruiser88 SILVER Star
    11,879
    Media:
    3
    Albums:
    1
    288
    Feb 21, 2006
    Winston Oregon
    you very well laugh at me for this one:eek: ok what do you guys recommend for transfer case fluid for a 88 fj62.#2i have never seen any gearoil for a transfer case red they dont make any do they.:confused: dumped my transfer case fluid today and its red just had they tranfer case rebuild:mad: its not really thin .and my transmission is not low either.i remember adding almost 1 quart 2 months ago because i saw a cooler line leaking a little.sence fixed.any ideas.and also the trasfer case dont leak a drop.sorry to sound so 1st grade
  2. cruiser88
    11,879
    Media:
    3
    Albums:
    1
    288
    Feb 21, 2006
    Winston Oregon
    well im starting to beleive the guy that rebuild the transfer case used tranny fluid rather than gear oil.reson being the transmission stick dont smell like gear oil at all.if this is the case what kind of damage could this do.its only been 4 thouand miles or so.
  3. cruiser88
    11,879
    Media:
    3
    Albums:
    1
    288
    Feb 21, 2006
    Winston Oregon
  4. cruiser88
    11,879
    Media:
    3
    Albums:
    1
    288
    Feb 21, 2006
    Winston Oregon
    oh i forgot to add there was no metal shavings at all:D
  5. Mace
    Mace rock scientist.. Staff Member s-Moderator
    21,623
    2,067
    Feb 17, 2002
    Las Vegas
    2 things, a lot of the new tranny's take ATF. So it would not suprise me if the monkey put ATF in your tcase.
    The second thing is that the seals between the tranny and tcase might be bad. if they are, ATF will get into your tcase.
    Personaly, I would fill the tcase with 90wt (or some multigrade gear oil) and then check it in a while.
    If it has not been driven a long way since the cnversion to ATF you should be fine. s***, the inside of your tcase probably has not been that clean in a very long time :D
  6. cruiser88
    11,879
    Media:
    3
    Albums:
    1
    288
    Feb 21, 2006
    Winston Oregon
    ok mace that was my plan.and yea its clean:eek: i was worried about bearing damage more than anything.i hope thats what he done because there was not even a hint of gear oil in the dan thing.:mad: .we shall see let ya all know thanks mace
  7. Cruiserdrew
    Cruiserdrew On the way there SILVER Star
    15,512
    4,474
    Mar 15, 2003
    Sacramento, CA
    Lots of USA t-cases are supposed to use ATF, so in WVa, the bubba who rebuilt your case likely didn't know any better. I think you are probably OK as well. Fill it up with 2.2 guarts of 80w-90 and drive it. If it turns red, then you are leaking from the tranny seal into the t-case.
  8. cruiser88
    11,879
    Media:
    3
    Albums:
    1
    288
    Feb 21, 2006
    Winston Oregon
    all is good no damage.:) i would have :crybaby: if so.i just sank 2 grand into that case
  9. Cruiserdrew
    15,512
    4,474
    Mar 15, 2003
    Sacramento, CA
    Wow-curious as to how? The rebuilt kit is $200, what does the other $1800 get you? Was the tranny rebuilt at the same time?
  10. cruiser88
    11,879
    Media:
    3
    Albums:
    1
    288
    Feb 21, 2006
    Winston Oregon
    it was supposed to be a pro that did the rebuilt.he said it cost 800 bucks just for the parts he bought.plus labor.this guy when i rolled up to his shop said he would look at it,so i did left it overnight.then it was he wanted 300.00 dollars down just to tear it down so i payed.then it was stuck there and i was stuck .the rest is history.next dam time i will do it myself:mad:
  11. cruiser88
    11,879
    Media:
    3
    Albums:
    1
    288
    Feb 21, 2006
    Winston Oregon
    no tranny never got bothered really only seals and filter
  12. Cruiserdrew
    15,512
    4,474
    Mar 15, 2003
    Sacramento, CA
    OK-good job anyway, you kept an old Cruiser on the road. But you're right, next time do it yourself. If I can do it, anyone can. As you are learning, there are very few people you can trust with your Cruiser.
