Transfercase bearings - is this a sound I should worry about?
I'm going to throw this out there to see what everyone thinks:
I've been slowly getting my 88 FJ62 into fighting shape over the last two years that I've owned it (I use it a lot as a DD, especially in the winter, so my maintenance and updates are very much done in spurts.)
Anyway, after a pretty major update of the rear axle (new bearings, new seals, Aussie Locker, rebuilt brakes) I got rid of a lot of sounds and vibrations from the rear axle. There is one sound left that I've NOT been able to track down and I think it's the output bearing of the transfer case. The sound occurs under deceleration conditions (i.e. lifting off the gas and letting the rig coast) and it sounds like a low "whump-whump-whump" and it IS speed dependent.
I'm pretty sure that its not the differential itself - when I got the rig i did a total rebuild of the front axle and I switched the differentials front to back.
So my questions are:
Is this something that is serious, or can I let it go for a while before i do a rebuild of the T-Case?
If it is the output bearings, does it then make sense to do a T-case rebuild?
If I don't need to do a rebuild, can I replace these bearings on the vehicle?
If I need to do a T-case rebuild, which I assume involves removing it from the vehicle, is there something else I should do and the same time while I'm at it?
As always, all opinions and views are welcome.
It's been my experience that throttle-based noises are typically pinion bearings, so you might want to check that out first. Finding these types of noises can be very difficult though.
As for the transfer case, here's my responses:
* If by "serious", you mean you are in danger of a catostrophic failure that will leave you stranded, I really don't think so. My only concern is that if that bearing (or any other) in the t-case is really that badly worn that the shaft can "walk" around in the case, which can lead to a very bad wear pattern on the expensive gears.
* My opinion on just replacing that bearing is, you should just do them all. It's unlikely that just one bearing is worn, they will all have some amount or wear. Read on...
* The rear output shaft bearing is reachable without tearing the entire case apart, but getting it out will be difficult. The actual race part of the bearing is held in place by the rear bearing retainer, that part is easy to get to. But, the roller bearing part is pressed onto the output shaft. It's unlikley that you will be able to find a puller with long enough arms and small enough "fingers" to grab this bearing to get it off the shaft, but there may be something that will do it. A regular 3-arm puller will not work, there's not enough room to get the fat arms around behind the bearing. In reality, the case will probably have to be split open, the output shaft extracted, and the bearing pressed off. Once you are this far, you might as well just replace ALL the bearings.
* You may not be aware of this, but the split t-case used on these trucks can't be removed as a unit and rebuilt on a bench. You have to tear it apart from under the truck, then re-assemble it from under there as well. Once you get the t-case apart, then you can make judegements on what other parts need to be replaced, things like the idler shaft, any of the gears, the thrust washers, etc. All seals and gaskets should be replaced. One thing that you may find is the output shaft from the tranny may have worn splines from the primary input gear in the t-case, this is a common problem with high-mileage FJ62's. Mine was BADLY worn, causing an ugly CLUNK when I shifted into D or from D to R. There is a good fix for this from a company in Austrailia called McNamara, they have a new input gear that has much longer splines. They are tough to get ahold of, though. I have rebuilt several t-cases with this gear and it is a good solution.
My sugggestions:
* Get a FSM (Factory Service Manual) for your vehicle. Read the section on the transfer case.
* Subscribe to the 3FE-based email group on Yahoo. Great group of folks on there that can offer lots of sage advice, I happen to be the moderator.
http://autos.groups.yahoo.com/group/3FE/
Good luck!
I rebuilt my 1984 FJ60 T case with basic tools. I took my time and got the entire rig jacked up as high as possible. You can sometimes tell if it is the output bearing by disconnecting the drive shaft and hanging on the output flange. It will move if it is bad. You will need a few big sockets and a basic press to remove some of the bearings, but if you take your time and keep things in order, it is not hard. I bought my stuff from Cruiser Outfitters for about $250 delivered. Curt was nice enough, but I left several emails and voice mails for him after the purchase and he never did call back. I guess he travels a lot and did not have time to answer. I spoke with a few guys in my club, who walked me through few areas.
Craig
2x on 'drive line noise changes with gas pedle' as being diffs (pinoin bearing).
But do get under your rig (with or without driveline attached) and see if you can move
output shaft/flange 'up and down' more than, say the thickness of a matchbook cover.
You can also put xfer in neutral, make sure front axles are 'unlocked' at hubs, one rear tire off ground & rotate drive line: listen for noise, feel xfer output housing for vibes. Although the driveline will be rotating slowly, you can still hear or feel the 'grindy' noise/vibes of a BAD output bearing,,,a bad beraing may a little harder to hear/fel...
X3 .. on this
You can rebuild your entire t-case withoute removing it from the cruiser ..
Sorry for the poor quality pic .. was taken with my mobil phone.
Did it make this sound before you swapped diffs? I put a bad diff in the rear and it made exactly the sound you are describing under deceleration only.
This is some good information - my initial thought was that it was the pinion bearing, but I seem to recall it always making this noise; however there were enough other noises coming from the rear that i may not have really noticed this noise. Now that things are much more quiet it's pretty noticable.
I do have the FSM ( i wouldn't have tackled anything on the Crusier without it!) and it's very useful; what i didn't realize is that the T-case can be rebuilt on the truck.
Could it be that both pinion bearings were bad? (It wouldn't surprise me, since this particular 62 had most of it's maintenance, oh how shall I say, ignored?).
I'll do a could of these things tomorrow when I do my oil change.
How about something simple like the u-joints? Those are almost always acceleration/deceleration dependent noises.
Well when I did the initial big service two years ago I did replace the u-joints. Now could one of those been bad? Quite possibly.
When I did my oil change this morning, I did a quick check of the drive shafts, everything feels pretty solid. So this doesn't really help. It is very likely that I do need a rebuild of the t-case and replace most of the seals (it's pretty juicy under my truck...)
Probably not the u-joints then. Did you use genuine Toyota, though? Aftermarket u-joints have been know to go bad in a few hundred miles.
I just always like to start with cheap and easy things first.
Damn holidays!
Anyway, I think i used cheap u-joints when i did the initial rebuild two + years ago. So that might be it.
I think it's time to re do the T-case anyway, so I'll probably start gathering parts to to this project in the spring once the weather is a bit nicer.
