So I have the same problem as many, an over-filled tranny and oil on my throwout bearing which appears to be from the transmission. The clutch is still operating fine and the oil has not reached the pressure plate but is indeed doing a nice job of lubricating the throwout bearing (hopefully is a side benefit). Strangely, my transfer was by no means empty. I assume the seal is blow at the front of the tranny but I don't have the time or money or energy to get into changing that now. Installing the by-pass hose from tranny to transfer and with the correct amount of oil added/subtracted, but not changing the seals, what are my chances of running like this for a while? Is it a sure thing to get oil on the clutch disc? Is the leak surely destined to get worse and worse or could the by-pass hose alleviate enough pressure to slow or stop the leak?
Thanks all...
Thanks all...
