Transfer Input Gear
Discussion in '40- & 55-Series Tech' started by allfoden, Feb 21, 2009.
  1. allfoden
    allfoden
    207
    2
    Sep 16, 2004
    Does the transfer input on 72 Fj40 have 29 teeth? Thinking about installing a new Fairey overdrive unit that calls for 29 teeth.
    Thanks
  2. cruiserjunkie
    cruiserjunkie
    2,007
    11
    Mar 11, 2008
    south eastern utah
    10 for a three speed case I think only a split case as 29 splines
  3. cruiserbrett
    cruiserbrett Moderator
    2,535
    82
    Feb 19, 2002
    San Diego
    the teeth count would be 29 or 31 for one piece cases. check here
    as for the input gear splines: 3 speeds are 10 spline, 4 speeds(early one piece cases) are 16 spline and IIRC split case are 19 spline.
  4. Living in the Past
    Living in the Past SILVER Star
    16,259
    2,988
    Apr 21, 2005
    10 spline 29 tooth three speed
    16 spline 29 tooth early four speed
    16 spline 31 tooth for the rest of the one piece transfer case era
