transfer case WTF?
Mclure BC CANADA
Im doing a quick "refurbish" on my case due to a split in my old one :D
basically parting a few cases together best parts blah blah. Ive done numerous rebuilds so I know whats going on.
Heres the deal, Im setting the preload on the main shaft(backlash whatever you wanna call it) and I have NO shims in the extension housing. the preload is too tight. I cant even turn the case. there are no shims in the nose cone either?
ummmmmmm.......................??????
Dan
Bearings/races are not seated properly...
:meh:
Did you mix up the sleeves? Not an expert, just an idea.
disregard!
Are the gaskets in place between the nosecone & case? Between rear bearing retainer & case?
If you are sure everything is right, but the preload is still too tight, try adding a second gasket between rear retainer & case.
maybe a bad bearing binding up
I ended up doing some fancy machining work to the extension housing. Seems to work now:rolleyes:
