transfer case & transmission breathers
miami, fl
can someone explain to me the reason to extend these breathers. from what i see these two breathers vent into the transmission fill tube, right? and the transmission fill tube has a "locking mechanism" on it. is it water tight?
thanks for the help
The end of the breathers only happen to be fastened to the outside of the tranny fill tube. There is no internal connection.
but it's high enough that I didn't bother extending it...
where do these breathers vent ?
Tools R Us said:
yea, but then again, those of us who know how to drive don't end up in big puddles like that.... :D :D :D :D
True
LX_TREME said:
Thats good one :D :D :D
Especially coming from you two, probably never seen puddles like that on them expeditions over to the mall?:doh:
On my last truck, all vents for any cases were centrally connected and then brought to the air filter housing which had a snorkel. Seemed like a very good idea to me. If I ever end up doing it, is there any reason not to do it on this truck?
Sounds like that would work well.
so, seriously, TRU, the axle diffs were OK in that incident but not the Case and Trans? that is somewhat sobering indeed. But then again that is a freaky hole...
thanks for the help
Extended breathers save you the cost of needing to change diff and other fluids that could be contaminated by travel through water. That cap on the end of the breather tube doesn't do beans for protection. The cost of the extended breather isn't significant to the cost of needing to do a change of fluids.
Kalawang
I had gone about 50 feet beyond that spot before hitting an obstacle underwater and was backing out, when it front end slid down into that hole. Even then it was making headway and would have made it out with minimal damage, if the motor had continued to run. Venting the distributor to someplace dry is the most important key to playing in water, my distributor vent will go to under the dash. There was no water in the diffs, the trans and transfer had to be flushed.
