Transfer case slips out of 4 Lo
Hi,
Looking for some help with a problem, my brother just bought a 82' 40 and when he puts it in 4 Lo the it slips back to neutral, any suggestions on what the problem is? Do we have a bad t-case or is it more likely a linkage problem? If you hold the shifter in the Lo position it will drive in 4 Lo. Thanks in advance for any help you can give us.
Check your engine mounts....remove the shift boot from around the range shift lever and watch it when you operate the vehicle and see if the lever is hitting the body when it is slipping out of low range.
If you have a second person to help you, go under the truck and identify the pivot arm that the linkage moves. Then have someone move the lever from hi to lo while you watch the pivot arm. When they are done, try to move the arm yourself from underneath the truck to see if it moves any further. That is another way to check for sloppy linkage.
If the linkage checks out [and it very well may] then it is most likely that the hi-lo shift fork INSIDE the transfer case is very worn and not moving the hi-lo shift sleeve fully onto the lo speed gear.
Best
Mark A.
