transfer case shifter location
KS
Where would the transfer shifter come out of the floor with a sbc350/turbo 350 with a downey one inch adapter. Iam going sbc350 in my 72 FJ40. I already have the Downey adapter and 350 trans,but I also have a SM465 trans, but no adapter. Which trans should I use. I will be doing more everyday driving than off roading and no rock climbing. Thanks for any info.
OC, CA
It can come out anywhere you want if you make your own linkage. :D
AA sells a twin stick shifter for a variety of transmissions and they seem to use the original opening location.
Cherry Valley, NY
I run a sbc305/turbo350 and the length of the automatic transmission moves everything back about 4 inches. My transfer case shifter is now relocated about 4 inches straight back from its original location. I had to cover the old hole, cut a new one, and fabricate a new trim panal with a shift boot. It was not all that hard--especially if you take out the tranny hump during the conversion.
Gus
Ridgway, CO
Go with the SM465, it's a stout trans and tons of people have done this conversion in cruisers, thus getting help should be pretty easy. My first cruiser had a 350/TH400, that trans was nothing but a headache until it died. Just my two cents.
Georgia Tech
[quote author=Pin_Head link=board=1;threadid=8097;start=msg68554#msg68554 date=1069909672]
[/quote]
Where does your SM420 adapter stick out PH? Haven't had time to install yours yet and see for myself. :D
