Can someone answer this question or who has modified/welded on them? I need to make changes. It looks forged. I've welded cast parts but would rather not. I'll just fabricate a new one if it is cast. Just checking before I go screwing it up.
Note: This feature currently requires accessing the site using the built-in Safari browser.
The only thing modified so far is the lug to the 2/4 shift rod. The rest is how it cam out of my 74. I know it is a later setup, but I didn't know it had been bent. It did seem weird that the H/L arm was at an odd angle. You don't know what you don't know, and this is how I found it behind the factory 4 speed.What part? What you have picture is a four speed transfer case shifter modified to work on a aftermarket setup. Can tell you the shifter that has the handle has been heated and bend back below the the point is bolts to shifter that shift into 4WD. Can see how the bent piece is not in alignment with high/low shift rod.
But, thank you for indirectly answering my question. If that was bent by someone, then it is most likely not cast. That is part of what I need to change and put back to where it should be. I'm putting a ball link there instead of that wonky connection. But, I guess it wouldn't be so bad if it were set up properly with the ball on the correct side of the H/L arm. Also need to put a z in the shifter lever and add some length.
Not much in that setup looks OEM. Been collecting parts for upgrading drive trains for years.
View attachment 2885401View attachment 2885402View attachment 2885403
Mixing and matching Land Cruiser shifters can makes things work will little mods. Not sure how well your current setup shifted between high and low ranges.
One of these is a stock 40 series with a H55F transfer shifter. The other is a 60 series shifter with 4WD lever from a later 70series, nothing modified just bolted together.
View attachment 2885420View attachment 2885419
