Hello all, I could use some advice with regards to whether or not I should rebuild or replace the transfer case on my 85 FJ60.
Short version: I am pretty inexperienced with working on my Land Cruiser but would love to learn and do more. My transfer case probably needs replacement or rebuilding. Is rebuilding the t case something I, being inexperienced, could do? What about replacing it?
Loooooong version
Some background on the problem. I started to notice a grinding/growling sound from my cruiser when driving around that was different from normal driving sounds (best description I can manage). Cruiser didn't make the sound while idling, only while moving. I took it to a cruiser mechanic in my area. He believes the issue is the transfer case. He drove it around, found the fluid level to be very low in the t case, and found metal shavings on the magnet of the drain plug. He recommended the t case be replaced but stated that without opening it up there would be no way to be sure that it is the issue. So while I am no sure that the transfer case is at fault, I concede to the mechanic's much more educated and probably correct opinion.
I want to replace or rebuild the transfer case myself, however my main concern is that I am very inexperienced with working on cars. However I really would like to learn how to work on my Land Cruiser and do most of the maintenance on it myself (after all that's one of the reasons I bought it). Is rebuilding or replacing a transfer case something I could do with a friend or is it better left to someone who knows what they are doing (which seems to be what the Haynes manual is telling me)? I would be able to work on the cruiser over weekends at an auto hobby shop on base but will be too busy during the week to work on it. I bought a second car recently so the cruiser is no longer my daily driver but I wouldn't want it to be out of commission for a long period of time.
If you made it this far, thanks for reading! Any input would be greatly appreciated.
Andrew
Loooooong version
Andrew
