After getting everything put back together (but still on the work bench) I'm second guessing something I came across in the process of rebuilding my transfer case this weekend. I noticed something and am not sure if it's ok or not. I installed replacement bushings on the high/low gears for the output shaft from Marlin that I picked up with the Terrain Tamer kit. My question is that after pressing in the bushings, new bearings, etc. the low gear spins freely but the high gear is locked in on the output shaft. Is that normal or should the high gear spin on the shaft like the low gear does? Unfortunately I didn't take notice of this before breaking everything down down for the rebuild so am not sure if it's supposed to be this way or not.
Thanks in advance!!
Thanks in advance!!
