Transfer Case rear output shaft seal
Yes, those are the parts you need. Forget SOR, take your VIN down to the local dealer and buy the parts there. Or, order them from c-dan on here.
I highly recommend you put some RTV sealant on the output shaft splines before you put the flange back on. This will keep gear lube from leaking out thru the splines, which actually may be where yours is leaking from now.
zebrabeefj40 said:
This is one case where the stock part is a marked improvement over aftermarket.
Nick
that goes for just about every replacement part IMHO...
-db-
You may be able to pull the nut and washer off of the output flange and just seal it up.
I just put the sealant on the inside of the washer to create a seal, be careful not to coat all the splines or it'll be really hard to remove later.
Toad
I'd bought t-case seals from SOR(not only rebuild kit but also individual seals) and found they sells same seal with oem seals from factory.
Oh, Min Seok
