Transfer case problem
Palm Harbor, Florida
Went wheeling today and my T-case would not stay in low, it would go into high but kept popping out. Anyone have any ideas? It was rebuilt last year and really hasnt been used much since the rebuild.
Silly as it may sound; check left engine mount (under smog pump).
If engine 'lifts' when applying torque (climbing steep hill for example) ; engine/tranny/xfer moves. shift lever bumps shift gate & goes to N.
Also note, (mine did it) if I pushed into Low xfer too hard, I'd pass Low & end up out of gear (i.e., neutral)
I just put new mounts on last year. I will look again and check if its broken again.
Hope it is nothing serious with the colornal. Any more dirty pics. still LMAO Doc:D Those 5 items you want should be ready some time week after next unless there is a manufactoring snafu. Luck. :)
Here you go doc-
Let me know on the 5 items, Ill bring the beer.
It turns out it is the springs on the Xcase- I need to get some stronger ones and problem should be solved- dont even have to drop the case. Will update once completed. Thanks all for the help.
