Hey all,
I have seen some discussion of similar issues in this thread but not EXACTLY the issue I'm seeing:
My 1975 FJ40 (4spd trans, 350 V8) shifts just fine between 2H and 4H, (up and down) but does not want to move from left to right, over to neutral or 4WD low. There seems to be a lot of "slop" in the T-case shift linkage (or a bent linkage) because I can push it all the way over to the edge of the transmission hump. When I do, it feels more like the stick is just bending, rather than actually going anywhere.
So far:
*Took off the shift boot, confirmed the linkage is indeed connected. Everything seems well greased.
*I've tried rocking the truck, reversing it, rolling forward, clutch in, clutch out, neutral, in gear, etc. with no luck.
I've read I should disconnect the shift linkage and try to manually shift the T-case into neutral and 4L from underneath - my question is, at what point in the linkage do I disconnect it? should I just remove the "stick" then reach down through the T-case hole and try to shift to Neutral? Trying to wrap my head around it. Pictures would help!
It looks like a single shaft that only moves forward and backward from what I can see - can't see how it would move to the right if I wanted it to!
If it is not a "linkage slop" issue, what might I be looking at?
So far:
