ThanksIt is manufactured by Aisin AI for the Toyota Motor Corporation.
It is a BF1A with vacuum actuation as stated above.
Does anyone know if the 80 series uses the same?
I don’t know if that’s quite right. All the 80’s have a HF2A, HF2AV, or HF1A and are all mechanical shift.I believe in the model designation nomenclature, correct me if I'm wrong, but BF is the type of transfer case, 1 means part time 4x4 vs 2 means AWD, A means vacuum shifted vs B means mechanical shifter for 4whl and low range. Correct? I believe what I have is a BF1B transfer case from a 2009 HZJ79 application.
Apparently the manual shift part-time transfer cases that I was referring to are the HF1A and BF1A.I don’t know if that’s quite right. All the 80’s have a HF2A, HF2AV, or HF1A and are all mechanical shift.
