I am looking for some help with a transfercase question. My plan is to put a turbo-1HZ, H55 with FJ62 (4.10)axels into a FJ60. I had to replace the aluminum housing on the transfer case that was mated to the original H55. The repalcemet housing and transfercase came from a US spec. 86 FJ60. Now I have two different sets of transfercase gears. The original gear set low range has a 1.99/1 ratio and the FJ60 gear set has a 2.3/1 ratio.
My question is : Is there any downside in going with the 2.3 ratio? Why did Toyota choose the 1.99 ratio for the 1HZ motor?
I cannot think of a reason for not using the lower ratio gearset. But I thought I'd post on mud to see if I was missing something.
I plan on using the completed vehical as an "expedition" vehical. Mostly offroad camping trips with a lot of highway miles in between.
Thank you for your input.
Frank Weber
Frank Weber
