Hey mud!
So I was on a shakedown run last weekend with my 5.3 set up, and I am running a split transfer a case from 1986. The guy Zack that sold me this set up had rebuilt this case himself back in 2018, and I am the first one to run it in 4WD.
I won’t keep this to a long series of symptoms, but basically my front driveshaft was not engaging, and I thought it was the hubs, but it ended up being opinion moving in and out preventing the output shaft gears from meshing with the pinion flange gears.
The pinion nut was cranked down also.
When I took the pinion flange off and the associated seal, this photo shows what was behind that.
My question is, should there be a retainer clip or seat clip of some kind to hold that bearing back in there so that it doesn’t move forward?
With the truck sitting in the driveway, I am not able to replicate the symptoms on the trail, I can engage four-wheel-drive and 2 Wheel Dr. easily, and the output shaft spins freely and locks as it should.
Any ideas?
Thanks!
Any ideas?
Thanks!
