The rear output shaft bearing came apart on my transfer case.
I can not get the adjustment shim or whats left of the bearing off the shaft. My cheap puller will not grip the shim or bearing to pull it off. Can anyone recommend a good puller that might catch the small lip that is on the center of the bearing to pull it off?
I can take a picture tomorrow if that helps. The bearing is gone it is just the internal part of the bearing left on the shaft.
I bought the cruiser like this. I figured the bearing was an easy fix.
Thanks,
Mike
Thanks,
Mike
