Transfer case, front output shaft bearing replacement
Sounds as though I need to replace brg.
have FSM, and have has split case apart before...
Plan on not removing front half of case from tranny . . .
Questions
1. FSM looks like front brg come out of housing as a unit,
not seperate bearing & race (races): CORRECT ?
2. How difficult to press out using C clamp & fixtures
I knbow wheel brg races can be tapped ( firmly) out
using a brass drift & hammer...
3. How difficult to press in new brg w/ C clamp & fixtures.
Oh, the noise it makes when in 4wd ( in or out of freewheel):
sounds like tumbling large rocks...
TIA
Pete
TLCA 6716 , FLCA 33
I'm not sure on #1 'cause I haven't had to replace that bearing yet. As for pressing out and in, that really depends on your creativity and ingenuity. I've replaced the tranny input shaft on a four speed in my garage using a 4x4 and a rubber mallet. I've also completely rebuilt a 3 speed transfer using a bottle jack and sockets and the weight of the truck.
I'd probably pull the front of the case though as it will increase your options.
Most anything is possible if you are creative
don't know too much on the 60's as all i've done is replace the input seal, but if it's the same as the 40 cases, the bearing is a one piece roller bearing part number 6306 (which is the same as the pilot bearing on any freightliner/kenworth/peterbilt with a 2" input shaft). on the older cases, it's easy to pound out of the old nose cone, and then with a 2x4 pound back in as far as you can, then use the old bearing to pound the rest of the way.
