I am working with some options and am not sure what to do.
I am thinking of buying an '82 FJ60 I found for parts. I want to put the axles under my '71 FJ40 (at least the front). I have also been toying (no pun intended) with the idea of building a centered hybrid rear axle as I lined up a '71ish rear axle housing and a complete '87 rear from a 4wd p/u (4 cyl).
I plan to install a SBC mated to a 700R4. I had planned to use a Dana 300 Tcase, hence the hybrid rear idea.
However, after talking with friends in my club I am thinking this through again. Some guys were suggesting adapting the 700R4 to the 3 speed case I have. Or going with a newer split case if I don't mind losing the e-brake.
So in comes the 1982 FJ60... It has a good t-case (where is the e-brake?). Would it be as easy to adapt that FJ60 tcase to the 700R4? It is a 19? spline versus my current 10 spline, but is it worth it?
I suspect a Dana 300 would be cheaper, but not having to build a hybrid axle is appealing too.
Thoughts and suggestions?
thanks,
Steve
thanks,
Steve
