LC4LIFE
Supporting Vendor
I’m only replacing front and rear output shaft bearings, but ran into this once I tore it down. The race has a little more wear on it than I’m comfortable with.I was gonna replace this bearing since the outer race could freely slide in and out of the housing but ended up using retainer compound to solve the problem. @LC4LIFE are you replacing all bearings or is there a problem with that one?
Revival
Are the front and rear output bearings usually the cause of whining? And maybe that one LC4LIFE was looking for?
My transfer is whining and if I can get away with just replacing those 3 bearings that would be great! Cheaper also
I guess I will find out this weekend. Gonna pull and tear down. Drained the oil and no glitter in it so that’s a good sign. From my experience when gears are worn you get glitter!
