- Joined
- Sep 17, 2005
- Threads
- 110
- Messages
- 638
- Location
- Vancouver, Canada
- Website
- www.jjadventuretours.com
Who has a tranny temp gauge?
Where is it (in the output line or in the pan)?
What readings do you get?
Do you have additional cooling?
My observations:
My temp gauge sender is in the output union (not the pan).
My temperature will spike up to 140+ C (high!) if I'm powering up long hills out of lock-up in 3rd (ie. not quite enough power/too steep a hill to get up the hill in locked 4th). Now this is the temperature coming straight out of the torque converter, NOT the overall tranny oil temp (ie measured in the pan), which should be quite a lot less.
I've found that I can stop this happening by shifting down (ie. to 2nd) and keeping the revs high (ie. above 2600 RPM). Then the temp only goes up to 110 C or so.
So when powering up big hills heavily laden or out of lock-up, keep the revs up above 2600 RPM to avoid burning up your tranny. This is probably nicer on your EGTs too.
My observations:
