Tranny/T-case splitting
Is there some trick to getting them apart. I have undone all the bolts I could find and still can't get them apart. Well, they are apart about an inch but won't go any further. Is there something that I'm missing? ???
what t-case/tranny?
FJ40 non-split cases are attached with 5 bolts, 3 visible and 2 behind the side cover. Split cases require complete disassembly to separate.
I have a custom plate that bolts onto the rear dome opening and uses a 3-jaw puller to separate them...works slick.
I've been able to separate the tranny and t-case using a 2 jaw puller between the tranny output shaft and two of the bolts from the transfer rear cover. You're pulling the bearing and tranny output gear off at the same time, that's why it's hard to get off.
