Tranny question?!
Long story. I will try to make it short. I went to the "nice" carwash today to get the salt off my rig. It is the type of carwash where they line the vehicles up and put them on the "assembly line" that pushes them thru. You know, the type where you need to put the vehicle in neutral. Dropped it with the kid who vacuums the interior and went inside.
Sit around for 10 minutes and finally see my 80 thru the glass. A 16 year old kid, an employee, is sitting in the driver's seat at the end of the carwash. It appeared as if he was messing with the gear shifter. No big deal. I look up 30 seconds later and he is just getting my 80 out of the line in order to dry it.
I leave the carwash and start to drive away. I get a mild sense that the tranny is shifting somewhat poorly, but not bad. Drive 5 miles to my parents to drop something off. I put it in Reverse to back into their driveway and hear a slight crack.
I leave and get 1/2 mile away and now 1st and 2nd gears bearly respond and are making a terrible grinding noise. 3rd and OD are fine. Reverse is just like 1st and 2nd gear. Park does not work.
My tranny is toast. My question is: Do you think if the carwash left the 80 in gear or park it would destroy the tranny like that, or was it just coincidence? The vehicle has 141K miles and I have never had a problem with it , as I have owned it for 14 months. I am debating as to whether I should confront the carwash about this incident. I probably won't, as it is very difficult to prove that they are responsible.
Any input is appreciated.
Check that the high low for the transfer case is firmly in high. Put the vehicle in transmession in N and shift the t-case, sounds like it is semi engaged in high. I doubt that it it the trans being toast.
Go up to the guy at the carwash and say "Do you want to f roller girl?"
Second that. check this and repost the results.
Low works fine, with no noise or grinding. When I put it back in Hi, same thing as above, grinding and poor response. The hi/lo shifter does not feel solid in the Hi position, even after several attempts to put it back in the Hi position.
Does this mean t-case problem?
It means that you are not getting it firmly into HIGH. Put the vehicle in N on flat ground and remove foot from brake pedal, FIRMLY! push the t-case back where it belongs.... in high..
OTOH there are scarse reports that if a lot of dirt or sand get up near the shifter it will prevent the shiftling as stated,,,, anyone remember anything about that?
I agree- sounds like the transfer case is not shifted all the way into high. Don't ask me how I know. :rolleyes:
Car wash kid was probably playing with the "extra lever".
I have done all the recommended procedures with no result. Any other suggestions?
Thanks for the replies.
Just drive it around in low range down the center median! JK
Could it possibly be a stripped flange joint on the front? works in low with CDL locked and not in high? maybe ? thinking out loud..
YES. Don't remember where though..., old 80scool archives I think. Dirk, this is well worth checking before pulling the t-case or anything else equally as drastic.
Also, I assume all of this has taken place with the CDL off (unlocked)? Might as well try locking it in High, see if that makes a difference.
Your statement "low works fine" was a little brief. Did you drive it that way enough for the tranny to go through all its gears to mimic the conditions when in High? Just want to make sure we're on the right track here.
Hang in there,
Curtis
