What length is that?I tow this regularly. Almost 4k loaded. It's a little slow on the high passes, but I have no complaints.View attachment 2028218
What mods are done to the truck? I'm looking at getting a 16ft.21ft.
good, i'm in the same boat, minus the armor.. lolNothing that helps towing! Full armor, 315's, a full size spare, and stock gears.
What brand/model trailers. I am in the market. I will probably rent a few different setups so I can zero in on the ones that fit my needs best. I'm thinking more like 19ish feet, double axle for stability, and only 7 ft wide for storage purposes.Nothing that helps towing! Full armor, 315's, a full size spare, and stock gears.
Jayco 174bh. 21ft long, 7ft wide. The single axle honestly isn't bad if you take your time to load the trailer the right way. We boondocks a lot and the added maneuverability of the single axle is a plus. I'm in the middle of a trip up the coast and I have no complaints. Currently in Redding, it's hot as balls here today and the trailer and the cruiser did great.
I am running airbags and a friction sway control.Thanks. 7 footers are pretty rare around Phoenix, but there are a few. I have been looking at the Clearview mirrors. Are you running airbags?
That's one sweet rig! Dig that 8274 up front too.
John,
I run airbags at 5 lbs when not towing. Truck is stable on highway curves at speed. Flexes fine on the trail at those pressures.
When towing the Kimberley, I inflate to approximately 10 lbs. Keeps the rig nice and level. Plumb the bags separately, don't Tee them together. More stable and truck is not always loaded equally side to side.
Jim
