TPS Adjustment
Pasadena, CA
So it seems my TPS may be out of adjustment or failing (weak spring syndrome). Do I have to remove the TB to get to that bottom screw?
-Aaron
Man... Both my 90 degree phillips were all but useless... Does the ISC require a new gasket if i remove it?
I prefer to remove the TB. I seem to get a better adjustment. It can be hard to get the feeler gauge in there just right with it all attached. Chances are the TB could use a good cleaning too. It uses a thin metal gasket and I have had no problems reusing it.
Just my $.02
